RAIJINTEK THEMIS, 3PCS 8MM HEAT-PIPE, 12025 PWM FAN, OPTION TO INSTALL DUAL FANS, SLIM TYPE 120MM HEAT-SINK - D:50MM, MULTIPLE MOUNTING KITS FOR INTEL AND AMD, EAS
RAIJINTEK THEMIS, 3pcs 8mm Heat-Pipe, 12025 PWM Fan, Option To Install Dual Fans, Slim Type 120mm Heat-Sink(D:50mm), Multiple Mounting Kits for Intel & AMD, Easy installtion and User friendly design Series: THEMIS Type: Fan & Heatsinks RPM: Air Flow: 65-70 CFM Noise Level: 20-25 dBA Power Connector: 4 Pin Color: Silver Heatsink Material: Aluminum & Copper
Price: 25.49
