RAIJINTEK PALLAS BLACK, HIGH-END LOW PROFILE COOLER, 6PCS 6MM HEAT-PIPE, SLIM 14013 PWM FAN, FULLY NICKEL PLATING, COPPER BASE, TOTAL 68MM HEIGTH INCLUDING FAN,
RAIJINTEK PALLAS BLACK, High-End Low Profile Cooler, 6pcs 6mm Heat-Pipe, Slim 14013 PWM Fan, Fully Nickel Plating, Copper Base, Total 68mm Heigth Including Fan, Supports Intel & AMD Modern CPU Sockets Series: PALLAS BLACK Type: Fan & Heatsinks RPM: Air Flow: 55-60 CFM Noise Level: 25-30 dBA Power Connector: 4 Pin Color: Silver Heatsink Material: Aluminum & Copper
Price: 49.90
