RAIJINTEK EREBOSS 6PCS 6MM HEAT-PIPE, SLIM 14013 PWM FAN, COPPER NICKEL BASE, OPTION TO INSTALL DUAL FANS, GIANT DISSIPATING FIN, MULTIPLE MOUNTING KITS FOR INT
Raijintek EREBOSS 6Pcs 6mm Heat-Pipe, Slim 14013 Pwm Fan, Copper Nickel Base, Option To Install Dual Fans, Giant Dissipating Fin, Multiple Mounting Kits for Intel & AMD - Black Series: EREBOSS BLACK Type: Fan & Heatsinks RPM: Air Flow: 55-60 CFM Noise Level: 25-30 dBA Power Connector: 4 Pin Color: Black Heatsink Material: Aluminum & Copper
Price: 52.90
