NOCTUA NH-U9S 92MM SSO2 U-TYPE PREMIUM CPU COOLER, NF-A9 PWM FANS, RETAIL
Noctua NH-U9S 92mm SSO2 U-Type Premium CPU Cooler, NF-A9 PWM Fans Type: Fan & Heatsinks RPM: 2000 RPM (Standard), 1550 RPM (w/ L.N.A.), 400 RPM (PWM) Air Flow: 46.44 CFM (Standard), 36.84 CFM (w/ U.L.N.A) Noise Level: 22.8 dB(A)/standard, 16.3 dB(A) (w/ U.L.N.A.) Heatsink Material: Copper ( Base and Heat-pipes), Alum.( cooling Fins ), Soldered Joints, Nickel Plated Compatibility: Intel LGA 2066 / 2011-3 & 2011-0 (Square ILM) / 1156 / 1155 / 1151 / 1150 AMD AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 (backplate required) Fan Mounting Types to Heatsink: Horizontal Max CPU Cooler Height: 125 mm
Price: 58.35
