NOCTUA NH-U14S 140MM SSO2-BEARING - SELF-STABILISING OIL-PRESURE BEARING CPU COOLER
Noctua NH-U14S 140mm SSO2-Bearing (Self-stabilising oil-presure bearing) CPU Cooler Type: Fan & Heatsinks RPM: 1500 RPM (standard), 1200 RPM (w/ L.N.A.), 300 RPM (PWM) Air Flow: 54.97 CFM (standard), 43.73 CFM (w/ U.L.N.A) Noise Level: 24.6 dBA (standard), 19.2 dBA (w/ U.L.N.A.) Heatsink Material: Copper (Base and Heat-pipes), Alum. (cooling Fins), Soldered Joints, Nickel Plated. Compatibility: Intel LGA2066 / LGA2011-0 / LGA2011-3 (Square ILM) / LGA1156 / LGA1155 / LGA1151 / LGA1150 AMD AM2 / AM2+ / AM3 / AM3+ / FM1 / FM2 / FM2+ (backplate required) Fan Mounting Types to Heatsink: Horizontal Max CPU Cooler Height: 165 mm
Price: 63.75
