NOCTUA NH-U12S 120X120X25MM - NF-F12 PWM SSO2-BEARING - SELF-STABILISING OIL-PRESURE BEARING CPU COOLER
Noctua NH-U12S 120x120x25mm ( NF-F12 PWM) SSO2-Bearing ( Self-stabilising oil-presure bearing ) CPU Cooler Type: Fan & Heatsinks RPM: 1500 RPM (standard), 1200 RPM (w/ L.N.A.), 300 RPM (PWM) Air Flow: 54.97 CFM (standard), 43.73 CFM (w/ U.L.N.A) Noise Level: 22.4 dB(A) (standard), 18.6 dB(A) (w/ U.L.N.A.) Heatsink Material: Copper ( Base and Heat-pipes), Alum.( cooling Fins ), Soldered Joints, Nickel Plated. Compatibility: Intel LGA 2066 / 2011-0 & 2011-3 (Square ILM) / 1156 / 1155 / 1151 / 1150 AMD AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 (backplate required) Fan Mounting Types to Heatsink: Horizontal Max CPU Cooler Height: 158 mm
Price: 62.45
