DYNATRON B3 INTEL SKYLAKE SOCKET FCLGA3647 NARROW ILM 80X80X15MM ALUMINUM PWM BLOWER FAN, COPPER SKIVING HEATSINK FOR 1U SERVER UP TO CPU POWER 165 WATTS
Dynatron B3 Intel Skylake Socket FCLGA3647 Narrow ILM 80x80x15mm Aluminum PWM Blower Fan, Copper skiving heatsink for 1U Server up to CPU power 165 Watts Type: Fan & Heatsinks RPM: At Duty Cycle 20%: 1000 +/- 200 RPM At Duty Cycle 50%: 4000 +/- 10% RPM At Duty Cycle 100%: 7000 +/- 10% RPM Air Flow: At Duty Cycle 20%: 3.0 CFM At Duty Cycle 50%: 12.0 CFM At Duty Cycle 100%: 21.0 CFM Noise Level: At Duty Cycle 20%: 16 dBA At Duty Cycle 50%: 44.9 dBA At Duty Cycle 100%: 57.1 dBA Power Connector: Pin1- (-) Pin2- (+) Pin3- (Tachometer/Signal output) Pin4- (PWM) Heatsink Material: Copper 1100 with Skived Fins Compatibility: Intel FCLGA 3647 Fan Dimensions: 80.00 x 80.00 x 15.00mm
Price: 34.99
