DYNATRON B11 INTEL SKYLAKE SOCKET FCLGA3647 NARROW ILM 80X80X25MM PWM FAN, ALUMINUM HEATSINK WITH HEATPIPE EMBEDDED FOR 3U SERVER UP TO CPU POWER 205 WATTS
Dynatron B11 Intel Skylake Socket FCLGA3647 Narrow ILM 80x80x25mm PWM Fan, Aluminum heatsink with heatpipe embedded for 3U Server up to CPU power 205 Watts Type: Fan & Heatsinks RPM: At Duty Cycle 20%: 1300 +/- 200 RPM At Duty Cycle 50%: 2300 +/- 10% RPM At Duty Cycle 100%: 4000 +/- 10% RPM Air Flow: At Duty Cycle 20%: 12.5 CFM At Duty Cycle 50%: 28.8 CFM At Duty Cycle 100%: 50.0 CFM Noise Level: At Duty Cycle 20%: 16 dBA At Duty Cycle 50%: 30.2 dBA At Duty Cycle 100%: 42.2 dBA Power Connector: Pin1- (-) Pin2- (+) Pin3- (Tachometer/Signal output) Pin4- (PWM) Heatsink Material: Aluminum Heatsink with Heatpipe Embedded Compatibility: Intel FCLGA 3647 Fan Dimensions: 80.00 x 80.00 x 25.00mm
Price: 39.99
